After purchasing a brand new Toyota group 27 TrueStart battery, it’s not living up to its “TrueStart” claim.
I’ve only had my 2011 GX460 under two months and I’m fighting gremlins, check engine codes indicating misfire on cyl 1 and 3. I also have a battery drain as well. Brand new battery drains overnight and won’t start at all. Jump starts just fine.
Battery drain: measured 13 plus volts while alternator is charging. The only actions taken son fee at was a deep clean of the neg battery cable to fender ground. Also to note: I have also installed the Hamilton CarPlay unit and that might be a cause.
Check engine codes: P0301 and P0303. These only come on periodically just after starting engine. The engine runs rough so I can feel the vibrations. However, turn off truck, push start button twice to get in ign mode, clear the codes and power off. Start engine and no codes, engine running smooth.
I don’t know if these two issues are related, but I mention them in case they could be.
I’m jinxed I truly believe. I bought an 80 series triple locked 1994 Land Cruiser. I was able to drive it five months until it would not run properly when pushing accel pedal. Suspect I need an engine bay wire loom. It’s been down ten months now.
Bought GX460 to replace Land Cruiser (which I still have but intend to sell it) and right away I’m getting codes and dead batteries. I can’t get any good karma coming my way.
Thanks for reading, letting me whine just a bit, but hopefully you can supply experience based suggestions how I should proceed.
Thank you all
Thank you all
