It’s a miss at idle. I’ve thrown every potential part
I have a miss at idle, and an occasional OBD1 code 25 (running lean) at idle that goes away a minute or two once start driving and pick up speed.
I've thrown every part I can think of at it with no resolution. I'm left at valves needing adjustment and injectors. Here's what I've done already: 99% OEM parts
| SPARK PLUGS (Gap Checked) |
| IGNITION COIL |
| SPARK PLUG WIRES |
| DISTRIBUTOR CAP & SEAL |
| DISTRIBUTOR ROTOR |
| FUEL PRESSURE REGULATOR / O-RING |
| IDLE AIR CONTROL VALVE & O-RING |
| VAF REPLACED WITH REBUILT |
| INTAKE AIR HOSE |
| PCV VALVE |
| 50% REPLACEMENT OF VACUUM HOSES |
| OXYGEN SENSORS REPLACED (2) |
| FUEL FILTER |
| OIL FILLER CAP |
| THROTTLE POSITION SENSOR |
| TIMING CHECKED (4 DEGREES) |
| SMOKE TESTED VACUUM LINES AT INTAKE (NO LEAKS FOUND) |
| EGR VALVE CLEANED-TESTED |
| IDLE CONTROL VALVE PORT CLEANED |
EGR MANIFOLD PORT CLEANED
IDLE AIR CONTROL PORT CLEANED |
