paint removal
Queensland Australia
Hi,
Does anyone know of a solution that can be made up to soak parts in to remove enamal paint.the parts are quite intricate and if i could soak them in something (home brewed)for a week and then just hose of it would be a lot simpler .
Cheers Shamus
Hi,
Cheers Shamus
Not too sure if you can get these. Xylol paint thinner will do the trick. Make sure no rubber pieces get in there. Also MEK(very hot) paint thinner will work. Home brew - oven cleaner works as well. I know it removes one-shot paint letters off of a truck.
Good luck
I always used MEK like webelk6 mentioned for removing paint or laquer off off very intricate brass scale models. Do it outside of course.
