Knock Sensor 1 Circuit High Input. First saw this code pop up about a year ago and then it went away on its own. It came back on about 2 months ago and has mostly stayed on. Occasionally I'll start the car and all the lights are clear, but then I'll start it next time and they'll be on again. Check engine, VSC OFF, TRAC OFF, etc.. Car seems to ride fine, other than when the code first pops up, it keeps the tranny going into 5th gear.
This code seems to be different from the 033 code I've seen referenced here. I see usually it's an issue with rodents chewing wires. However, I happen to have a bad exhaust manifold leak and it ticks like a bastard. Any chance that that's what's causing the knock sensor issue? I'm obviously being hesitant to take it to a shop on account of the expensive labor to open up the intake manifold, let alone replacing the parts. Sounds like it depends on the shop, because some might only be willing to replace the whole wire harness which can be very expensive, making this repair potentially $1500 or more..
Any chance that fixing the exhaust manifold leak will take care of this knock sensor issue?
