P0206 V8 D4D
Namibia
hi...newbie here :-)
got a 200 v8 d4d, 75.000km and 2011 model......engine gives a bit of trouble....at idle uneven run, limp mode when driving....throws fault p0206 injector 6 circuit....now the shop says it's a mechanical problem inside the engine (e.g. bend conrod)......anyone out there with a similar problem in the past??
ah ok, so most likely the solenoid of the injector giving the trouble code/is faulty?
funny is the injector values are fine but yes could benthe injector itself then.....possible to replace only one injector or must all be replaced?
With a 200 being that new, I would just replace the one but only after verifying the currents are correct and within spec.
