1997 FZJ80. I've spent half the day in the manual, searching and reading posts, inspecting visual and using OBD 2 reader. Here's the symptom: P0115 continues to come back after clearing. The thermostat, sensor and the harness (wrapped with heat tape) were replaced 20K miles ago with new OEM during engine rebuild. Blue fan clutch.
OBD 2 readings (2 different phone apps):
181-184 F then peg out at +280 F for a couple seconds, then return to 181-184 F.
Dash gauge consistent around middle of gauge
Indicates short circuit per FSM page DI-31, skip to step 4
Disconnected ECT sensor per FSM and read -40 F
Replace ECT sensor per FSM page DI-32
Before I replace the sensor, I'd like to figure out the jumping back and forth from correct to +280 F. Would a bad sensor jump in values or stay pegged at max, or could it do either one? If I understand the mechanics of the sensor correctly, it should stay maxed if bad. I know the FSM doesn't point to this but it acts like its an intermittent short somewhere deep in the harness. If that's the case, would I need to replace the sensor to properly diagnose?
