This morning, the check engine light, the VSC Trac (a-trac) and VSC OFF lights lit up on the dash. I disconnected the battery for a few minutes and that temporarily cleared the lights but sure enough, they came back on after about 10 miles or so of driving. This evening, I borrowed a friends reader to find that the code from the check engine light was "P0051 - Heater control circuit low (bank2, sensor 1)"
Here's what i noticed. When i start the truck, the check engine light is on immediately. After the truck has been on for about 10-15 seconds, the other two warning lights come on. Hopefully some of you can answer my questions.
1. Can this code cause the VSC lights to illuminate?
2. If this is an O2 sensor that needs replacing (from something i read previously) is this a warranty item that can get covered if i am still under warranty?
3. When/if i bring the truck to the dealership, would you recommend removing my BIOR skids? (i would think so right?)
4. If the code and the VSC lights are independent of each other, any ideas what to look for?
Any help would be greatly appreciated.
NOTE: I checked the CDL switch. When i press it, the light goes on, on the dash and when i press it again, the light goes out. That was the first thing i checked.
