P0031 - Heater Control Circuit Low (2 Viewers)
USA
2003 LC. My CEL light came on today during a short drive. Scanned and it’s showing P0031, Heater Control Circuit Low. I haven’t reset it yet to see if it comes back.
I searched the forums and saw a couple of posts that stated replacing the faulty sensor fixed the issue for most, but...
  1. How do I determine which sensor is bad? The error code wasn’t specific.
  2. My truck occasionally has the exhaust “tick-tick-tick” so I know it has a leak somewhere in the manifold. The ticking noise isn’t that bad at all though, and it’s not always audible. Could a failing sensor mean the leak is getting worse? We don’t smell any exhaust fumes while driving around.
  3. Somewhat related to this post... I think I might try this in the next few months:
    Note: This video goes over repairing exhaust manifold leaks/small cracks using Extreme Heat High Temp J-B Weld. That's what I am referring to trying in the next few months. The Youtuber stated he did it about 8 years ago to his truck and hasn't had issues. My exhaust system does not have any huge holes in it.
Thanks!
To answer my own question (how do I determine which one is bad?), I checked the service manual. Yep, I should have done that first. :)
P0031 - Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 1)
  1. For those who don't have a service manual (and you are just unlucky and can't find an answer using google): You will have to pull each one and use an ohmmeter to measure the resistance between terminal +B and HT.
    Resistance:
    11 - 16 Ω at 20 ° C (68 ° F)
  2. If resistance is not as specified, replace the sensor
    Torque:
    44 N-m (450 kgf-cm, 32 ft-lbf) for sensor 1
    20 N-m (200 kgf-cm, 14 ft-lbf) for sensor 2
According to the service manual I will need to take the Engine Under Cover (front skid plate) off to access this sensor and replace it (if it is faulty). I was hoping I could access it from above. Anyway, I've cleared the faults, and it came back after driving for 15 - 20 minutes, so it is more than likely faulty. I will try to get at it and measure the resistance. I am also going to order a new sensor. $66 for a Bosch (exact fit) sensor... with the $15 off coupon I found... and that's with next day free shipping!
Bosch Exact Fit Oxygen Sensor
Part Number: 13441
Application: Upstream sensor (located before catalytic converter)
check fuse and relay?
I scanned via OBD-II to get the code once the CEL came on. Do you think this could really be because of a blown fuse or bad relay? If so I will check. Which fuse(s) could be potentially cause this code (P0031)?
couldn't say, make sure it's a clean fuse though. Look in manual or your FSM.
I don't really know if that's it, but I would at least check that first. The light comes with under/over voltage amp in the ecm. I don't know what code would come first though as far as the four sensors, working off one fuse/relay
edit, yours is low.
Your O2 is bad. It has a electric heater in it to speed up it's warm up time, the o2 sensor needs to be warm to work properly.
You only need to remove the middle skid plate.
Replace both sensors at the same time.
Run the singe and get the exhaust hot, this helps you break the rust free.
Make sure you use the proper tools, rent or buy a O2 tool.
When you say replace both, you mean both the upstream and downstream on bank 1, right? My bank 1 upstream is bad according to the P0031 code. I suppose it would be prudent to replace both to keep them a "matching" set. I went ahead and also ordered the downstream sensor. I don't think I need to replace all 4 at this point, right?
I ordered an O2 tool from amazon. Hopefully it isn't junk.
edit, yours is low.
OK, that's a good point! I will check in the manual to see if I can narrow it down to a couple of fuses and check those. It would be frustrating if I found a bad fuse at this point, since I already ordered both upstream and downstream O2 replacement sensors.
No. Both fronts. Replace both fronts. Then when the rears go bad replace both of them at the same time.
The front O2's do all the work, the rears only monitor the catylictic converters and tell you if those are working or not. That is all they do. The fronts monitor engine fueling etc.
Thanks for the clarification!
Just had the same issue with my '04 (164k mi). Both VSC lights came on as well, which I see from a separate thread probably doesn't actually indicate a problem with the VSC. I'm going to hope for the best, anyway, and assume it's just the O2 sensor.
Question: How urgent is this? I rely on my truck as my DD and am going to be using it to move over the next few days (I know, perfect timing). Is it likely I'll fry something if I run it for a few hundred miles before fixing it?
I am curious what ended up happening. I just had this happen with my lx and I was not planning on replacing o2 sensor any time soon. Is it ok to run in that condition. I will probably run fuel heavy but I don't think it will hurt anything else.
  1. How do I determine which sensor is bad? The error code wasn’t specific. View attachment 1759135
Thanks!
Hey Partner. Did replacing those front Sensors fix your issue?
