Optimum scrub radius thread
This is what I get assuming a 13* SAI:
Tire Size - Rev/MileDriven Diameter - inIdeal Offset Change(negative direction) - mmTire Reference
66530.3-Approximately Stock LX570 285/50R20(665)
66030.60.0Approximately Stock 200 Land Cruiser 285/60R18(662)<-Used as zero point
65530.80.7Approximately Stock LX570 275/50R21(656)
65031.01.4-
64531.32.1-
64031.52.8Typical 285/70R17 range
63531.83.5Typical 285/70R17 range
63032.04.3-
62532.35.0-
62032.55.8-
61532.86.6-
61033.17.3Typical 315/70R17 Range
60533.38.1Typical 315/70R17 Range
60033.69.0Typical 315/70R17 Range and 35x12.5
59533.99.8-
59034.210.6-
58534.511.5-
58034.812.4Typical 37" tire range
57535.113.2Typical 37" tire range
57035.414.1Typical 37" tire range
56535.715.1Typical 37" tire range
56036.016.0-
55536.317.0-
55036.717.9-
54537.018.9-
54037.319.9-
53537.720.9-
What is the definition of 'driven diameter'? For example the 35x10.5x17" tires I run are 34.6" diameter . . . I previously ran 275/i80r18 which were 35.3" diameter. I'm asking as the Tire referrence column seems to be about three rows too high.
I think you can order EvoCorse's as a +45mm too.
That was my recollection too. They weren't listed on the maine overland site just now. Could be a search error on my part. Perhaps a custom order?
Driven diameter is the published REV/mile converted to diameter. So:
5280/Rev per mile = Driven circumference
Driven Circumference/Pi = Driven Diameter
A 35" tire with a 34.6" actual diameter does not put the hub of the truck at 17.3" off the ground. Its lower than that. Unfortunately, Kenda doesnt seem to publish their Revs/mile
My Territory MT 315/70R17's have a spec diameter of 34.4, but the Rev/mile is 608, which puts its driven diameter at a 33.2. When I actually go measure my ground to hub distance, its more like 16"
Ok, it's the 'squished' measurement, got it.
For funsies I put in the stock size rim/tire vs RW vs my current rim using my current tires to see what the scrub lands at. The scrub radius is the distance on the ground that the center line moves. It isn't a 'squished' measurement in this tire calculator.
RWs (17x8, 50ET) + skinny 35s (35x10.5x17) is a zero scrub change from stock (20x8.5, 60ET) with 285/55r20 tires.
ET Alphaequipt Echo (17x8.5, 35ET) + skinny 35s (35x10.5x17) is 16 mm positive scrub change from stock (20x8.5, 60ET) with 285/55r20 tires.
Which is essentially what my table says. The Rev/mile for a 35" tire is right around 600 so 9mm offset change from the stock tire/wheel
