8/16 update below
Welp, sold my Challenter SRT and picked up a 1998 LC100 from Japan. Body is straight but needs paint. AHC is shot and I'd rather just replace it and not deal with AHC headaches (yes, I've read the FAQ). I want this to be a fun daily with the ability to evacuate due to hurricanes (and maybe some off road fun). I plan on keeping the JDM aero kit, keeping it black and then putting on some nice wheels and fixing the suspension, so that's what I'm doing. I'm just kind of keepint this thread more for me and seeing all the stuff I'm having to update/replace. A HUGE positive is that it freaking runs like a champ. It has only surface rust, 98k miles and timing belt was done last year.
Some interesting things I'm learning. The JDM LC100s in 98 did not have any kind of OBD port and use just the Toyota data port. One shop couldn't read some modules because they need the JDM reader. I purchased a JOBD scanner on Amazon not realizing there isn't an OBD port. So if anyone has any suggestions on how to read the JDM modules it would be appreciated. I know about the pin jump to get the flashing CEL codes, but would like to have a port reader.
1998 Toyota Landcruiser 100 Series (2UZ) - NOT triple locked
555 UCA
555 LCA
SLEE diff drop kit (did not install as I saved my AHC)
OME rear HD LCAs
OME rear coil springs (did not install)
OME tie rod kit
OME torsion bar
Eibach f/r 2.5" shocks (did not install)
Bushings (basically all of them...)
Battery
Alternator (second one)
fuel filter
hood struts
Coil packs
Plugs
Air filter
170d tstat
Tensioner pulley bracket and pulley
Idler pulley
Fan cluch bracket and pulley
fan blade
AC condenser (will wait)
Window trim
555 UCA
555 LCA
OME rear HD LCAs
OME tie rod kit
OME torsion bar
Battery
fuel filter
hood struts
Coil packs
Plugs
Air filter
170d tstat
Idler pulley
fan blade
Window trim
