Hi Y'all,
This month's meeting is at my house and is combined with a HAMOM. I will be replacing the rear wheel bearings on the 80. Both bearings are loose and causing tire wear problems. I had considered replacing the 100's timing belt, but decided to wait until the following weekend.
I plan to get started about 9am. Stacy will be fixing chicken and ribs for lunch (likely a few snacks too). I would kindly request a $5 donation to help pay for the meat. I'll let Greg chime in on the meeting portion, but I would recommend starting the meeting after lunch, say 1pm.
As far as the HAMOM, at a minimum, I'll be replacing the rear wheel bearings on each side. Depending on time and part condition, I might replace/rebuild the rotors, calipers, parking brakes, pads. I should be in good shape as far as tools and equipment. The only thing needed is the SST for the bearing adjuster (Jon can I borrow your's?).
If anyone has some other maintenance to do that day, you can post up and we can try to accommodate. I have a driveway big enough to work on my truck and another. Plus I have the garage.
Hope to see a big group on Sunday!
