Since pretty much all of NC got smacked around by Florence and Michael, it would be a good time to have a place for ONSC member businesses, or ones they recommend to post up. Anything related to get a home back to livable, inside, or out. Would be best to say what geographic region they serve, what they offer, and any contact info you feel comfortable providing.
For example, I'm in Greensboro, and will be needing the following work done at some point in the near future.
Roof and gutter work
Siding (would prefer insulated vinyl siding.
Inspection of existing sheathing, vapor barrier and insulation on exterior walls where I had water intrusion.
Windows, some replaced, some pulled out and the frames resealed to the house (insert rolleyes here)
Someone to test for mold in exterior and interior walls (my wife has a compromised immune system, so this is a biggie)
HVAC/Heating. Both service doors were blown off my hvac and furnace, and there was water staining on top of the unit, and inside the unit. AC has a bit of a musty smell, even with new filters. There was a little bit of mildew or mold starting to form on the outer case of my humidifier (which was summerized back in April).
Some plumbing work
Drywall work, including some ceiling work
Paint work
Flooring
The trunk and heavy end of the tree for tree removal, and stump grinding for 1-3 houses on my street.
Post up if youre in the trades, the area you support, etc. Also, who you recommend, and who you DONT recommend.
Thanks,
Steve
Some plumbing work
Paint work
Flooring
Thanks,
Steve
