Hey guys,
I just finished up the install of my OME lift on my 100. Currently the rig is measuring at 36" from the ground through the center of the hub to the lower edge of the fender. My ride height is just about 12" on every wheel. (The 05's came with 18" "dubs" so that left me getting 1/2 - 1 " lower measurements than everyone else from the top of the wheel)
I know the front is adjustable depending on where I index my T bars at. I just don't want to go higher in the front if my rear is going to sit lower. I guess my questions are:
1. Whats your height from the ground through the hub to the fenders? I'm at 36" on all four.
2. Is there any other way to increase my rear height so I can crank up my front? (Spacers?) I have the 865's installed.
3. Those of you running 13" wide tires on factory wheels, what backspacing do they have? I know Slee has the 13's but is using spacers.
Christo did you have to because of rubbing the control arm?
Thanks for any help in advance,
Doug M.
Doug M.
