OME 868 Springs this month
DOWN UNDER
Website
www.the-shed.net
I see ARB is making a heavier spring for the 80/100 series now, available this month I believe.
The OME868 has the same free height as the current OME864 coil, but is made with 21-mm material instead of 20-mm. This also increases the spring rate on OME868 to 360lbs, where as the OME864 is 320 lbs.
Might be an option, if you cant leave anything else out of the car when packed 8-)
Darren McRae
