So I'm trying to do the "fog lights on when you want them on and not just when the headlights are on" mod on my 06 TLC. It's a pretty easy walk through except for some insane reason, there is no fog lamp relay in my fuse panel on the left side of my engine compartment. Everything I've researched says it's supposed to be there, including Mitchell and a fuse box map from Toyota, but, it's just not there. Here's where it gets crazy. When you turn the fog lamps on and off you can hear a clicking coming from that fuse panel, loud and clear. I can't find a single thing about this mod where the relay is NOT in that fuse panel.
Any chance someone else has heard of this, or come across it? I suppose the only way around this if I can't figure it out is to run a complete new wiring harness with relay and switch which is sure to be a HUGE pain. Hopefully someone here can help! Thanks!
