Read on either the 40 board or this one about oil pan bolts being loose. This captured my interest as I had noticed that the metal panel (below the spark plugs) on the PS was leaking, and mostly becuase the bolts were really loose. I tighten them to spec, and no more leaks. I've seen some leakage at the rear of my engine for quite awhile, and assumed it was the rear main seal. When I read about loose oil pan bolts though, I went and checked. Spec is 61 in/lbs, none of mine were even close. Most took 2-3 full turns to get to factory spec. Have no clue whether this will make a difference in oil consumption, since I just did it a few hours ago, but thought some of you might want to check this simple thing. Who knows, maybe my rear main is OK?
Best Regards,
Best Regards,
