From the FAQ at the top, a search, and your owner's manual:
CAPACITIES
Engine, with filter..........7.2 quarts[1]
Cooling System, W/o rear heater Initial Fill..........15.0 quarts
Cooling System, W/ rear heater Initial Fill..........16.0 quarts
Automatic Transmission, Initial Fill..........3.7 quarts[2]
Automatic Transmission, Total Fill..........12.0 quarts
Differential, with Locking diff Rear..........6.8 pints
Differential, witho Locking diff Rear..........7.0 pints
Differential, Front..........3.6 pints
Transfer Case,..........2.7 pints
1. Capacity shown includes filter. after refill check oil level
2. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....18 ft-lbs
Transfer case
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
