OEM Roof Rack Delete... Anyone actually done it? Leaks?
Looks like this is no longer available.
I'm very interested in removing the roof rack at some point - can someone confirm whether part numbers would be the same for a 21?
Click the Amazon product description and it lists all the part #s in the kit. I’m sure those parts are still available separately if that’s the route ya need to go
Yep, thanks. I can source the parts directly from my local dealer using the #s.
I was a bit confused because the Amazon link said they fit up to 2019 but that doesn't make any logical sense so I'm going to assume they'll be fine.
No Promblemo
I know different years and the LX variant have a couple different racks. The older relics, like my 2010 have a full OEM rack, the LX variant, and I THINK the newer LC variants have a shorter one so it needs less parts, but they’re the same nonetheless. Could be wrong though
No Promblemo
I can always ask the dealer.
I'm not aware of any changes to the roof rack after 2018 but admittedly I'm not sure.
You've given me enough to be dangerous. Appreciate it.
Hey All
Found several threads showing the OEM factory roof rack delete kit, which i will be ordering shortly.
But i havent found any threads where someone actually used and installed it....?
Anyone here done it and can confirm that water intrusion is a non issue?
Thanks
Did you end up deleting your rack?
Im wanting too. Just worried about dropping the nut retaining down.. lmk thx
