OEM LC UCA vs. FJC UCA?
Denver, CO
I have aftermarket UCAs from Light Racing, had them on my 08 FJC. I wonder if they will fit on my 01 LC? Is the OEM part the same on the 08 FJC, as the 01 LC?
Anyone have an idea?
I was able to slide the LR UCA up close to the OEM LC UCA and man it looks spot on. I did not keep my OEM FJC UCAs, that would have been smart.
Any thoughts you have would be great. Planning on doing my lift in the next few days and wondered if I should do a fit test on the LR UCAs?
Onur, Any thoughts?
To my knowledge, they are not the same. Alignment tabs on the LC are part of the UCA mounts, alignment tabs on the FJ are down low. I have called LR about UCAs for the 100 and if they get enough requests they will consider making them.
hmm, did you also have LR UCAs on your FJC? Or did you stick with OEM UCAs, after your lift?
The alignment variables are all part of the ball joint mount on the LR.
I am heading over to LR today to replace my cores, too bad I can't replace them with 100 cores.
Bug em about making some UCAs for us.
I'd probably get em if LR made them. It would be nice to have a sub $700+ dollar option.
