I rebuilt the stock brakes on the 25 (no booster, single reservoir master cylinder, single cylinder at each wheel). Now I have this heat related problem. When the motor gets hot (not necessarily the brakes) the brake system builds up pressure and applies the brakes.
Here's an example:
Last night (70 degrees) I took it out for a test drive. Everything was fine (with the brakes :
) during the drive. Parked the truck and a few minutes later the brake lights came on (pressure switch). The brakes were rock hard at the pedal and were dragging. The brakes slowly loosened up as the truck cooled down.
Things I've suspected and tried:
1- Air in the line that runs behind the valve cover heating up and expanding. Bled the system repeatedly and haven't got any additional air out.
2- The actuating rod between the pedal and the master cylinder has plenty of free play.
3- Master cylinder check valve. Initially I thought this wasn't supposed to be in there, but it is, and it looks and works fine.
So any ideas? Wild theories? This is all stock 1950's technology which I once thought was very simple.
Thanks,
Here's an example:
Thanks,
