Did you ever work this out ? Trying the same thing with torque pro .I was playing with building some OBDFusion screens today and wanted to monitor engine oil pressure. There was a parameter for this in the softwhere but with the vehicle running, it goes away. I have the Toyota PIDs and there does not seem to be any oil pressure available. I searched here and found this thread. Anyone found an oil pressure on their OBD2?
No. There doesn’t seem to be any actual oil pressure signal available on the OBD. I think the oil pressure sending unit is a on/off type switch and not a pressure transducer/transmitter. Does seem weird as the dash is a gauge.Did you ever work this out ? Trying the same thing with torque pro .
The gauge on the dash exits so surely there is a PID somewhere!?
Interesting. Most of the gauges on the dash I thought were actually fed via canbus. How is the oil pressure light triggered?Our oil pressure sender has a diaphragm that moves a potentiometer to alter resistance on a single wire.. and this goes straight to the gauge cluster, nothing to the ECU (unless the cluster then sends a signal to the ECM via CANBUS)
It is strange to me that the ECM wouldn't have an oil pressure input.. as pressure will be important for the variable valve timing our engines have. But per the wiring diagrams this seems to be the case.
Interesting. I guess that just sets off the oil light on the dash if the engine oil temp is too high?Per the wiring diagrams 16+ added a 'thermo switch' to the low-oil light switch for the gauge cluster, but no additional pressure senders to the ECM. That's the only relevant difference I can find.
08-15 low oil switch
16+
The odd thing about the oil temp switch is as long as the level is still adequate the circuit should be closed so I don't know how the thing works. Or maybe it is a closed circuit (whether from excess temp or inadequate level) that triggers the light?Interesting. I guess that just sets off the oil light on the dash if the engine oil temp is too high?
I can read oil temp on my 2013 via OBD Fusion but I have no idea what's "bad".
The FSM indicates there's a power steering oil pressure switch too though I don't know how it alerts you to a low pressure situation. It says 3 cycles in a row will illuminate a MIL but I don't know which one. ¯\_(ツ)_/¯
I get that but it's just not in the EWD. And not that those are absolutely perfect, occasionally they'll get a connector designation wrong or something, but for a complete circuit to be left out of all years of 200 would be odd, to me.I dunno but OBD Fusion has a PID for "Engine Oil Temperature *F" and it reports differently from the A/T temps and the coolant temp.
I've noticed the FSM doesn't always seem to include every bit of info about how stuff works. It's really around repair diagnostics and replacement of parts, so if it's something only reporting into canbus and only used by the ECU there might not be a lot of info available to us about how it operates if Toyota assumed we wouldn't use the info to make a diagnostic decision (regardless of whether the ECU uses the info).
