Novice DIY'er
Alberta
Hey Gang,
Love my 03 Runner but am having issues with the power windows. Can anyone tell me if:
- there is a fuse for the rear windows
- you need to pull the door panels off to change switches
I'm not cheap by nature. Just been "restructured" from my job a few months ago so, if I can save some $'s...
Thanks!
Did you recently replace the battery? If so you need to reset the windows.
Hey White Stripe,
I did replace the battery. Any advice as to how to reset them?
Fear that it might be the master switch still as the front windows work properly. I watched a Youtube video where the guy replaced the switch on a Sienna. Super easy. Didn't need to remove the panel. Just popped the casing off from the top.
Does anyone know if this is the same with a 4Runner?
Thanks again!
Hey White Stripe,
Thanks again!
You have to go to each door and use that doors window switch to roll the window down, then roll it up, when iit gets to the top keep holding the switch in the up position for 5 seconds. Do it for each window.
