Dealer Reported 09/01/2009
Lexus of Rockville Centre 49985 0628298 OTHERS CUSTOMER REQUESTS TO REPLACE DRIVE BELT - REPLACED DRIVE BELT
Lexus of Rockville Centre 49985 0628298 ACCESSORY CUSTOMER STATES WHEN SHUTTING OFF CAR THE 4 WAYS FLASH. DASHBOARD LIGHTS COME ON.. CHECK AND REPORT - NO PROBLEM FOUND
Lexus of Rockville Centre 49985 0628298 25 POINT CHECK CUSTOMER AUTHORIZES COMPLIMENTARY 25 POINT SAFETY INSPECTION - 25 POINT CHECK - 25 POINT CHECK
Lexus of Rockville Centre 49985 0628298 TENTATIVE APPT. WE HAVE MADE A TENTATIVE APPOINTMENT FOR YOU 6 MONTHS FROM TODAY. OUR APPOINTMENT DESK WILL CONTACT YOU ONE WEEK PRIOR TO YOUR DATE TO SCHEDULE AN APPOINTMENT AT YOUR CONVENIENCE. - TENT APPT - TENT APPT
Dealer Reported 04/22/2009
Lexus of Rockville Centre 47035 0618963 NYSI W/ EMISSIONS CUSTOMER REQUESTS NYSI WITH EMISSIONS. - INSPECTION DUE. - INSPECTION COMPLETED.
Lexus of Rockville Centre 47035 0618963 50,000 MILE SERVICE REPLACE ENGINE OIL AND FILTER ROTATE TIRES INSPECT AND TOP OFF ALL FLUID LEVELS (IF APPLICABLE) ADJUST ENGINE DRIVE BELTS INSPECT ENGINE SETTINGS LUBRICATE DOORS AND CHASSIS INSPECT STEERING LINKAGE INSPECT BOLTS, NUTS ON CHASSIS INSPECT AND RESET TIRE PR - 50,000 MILE SERVICE - 50,000 MILE SERVICE
Lexus of Rockville Centre 47035 0618963 OTHERS C/S AT TIMES THERE IS A HUMMING SOUND FROM ENGINE - CUSTOMER WAS ADVISED THAT VEHICLE NEEDS AN ENGINE DRIVE - BELT..SEE MIKE OR CALL HIM..ALSO VEHICLE NEEDS A WHEEL - ALIGNMENT AND BY NEXT SERVICE WILL NEED FRONT BRAKES AND ROTORS....SEE MIKE
Lexus of Rockville Centre 47035 0618963 TENTATIVE APPT. WE HAVE MADE A TENTATIVE APPOINTMENT FOR YOU 6 MONTHS FROM TODAY. OUR APPOINTMENT DESK WILL CONTACT YOU ONE WEEK PRIOR TO YOUR DATE TO SCHEDULE AN APPOINTMENT AT YOUR CONVENIENCE. - TENT APPT - TENT APPT
Lexus of Rockville Centre 47035 0618963 WHEEL ALIGNMENT WE FOUND REAR BRAKES WORN DOWN - REAR BRAKES WORN AND ROTORS WARPED..BRAKE JOB COST $442.00 GAVE CUSTOMER $100.00 OFF FOR PAST CREDIT. - REPLACED REAR BRAKE PADS AND RESURFACED ROTORS
Dealer Reported 01/28/2009
Lexus of Rockville Centre 43918 0613644 ACCESSORY C/S CD PLAYER IS INOP.,INSTALL SOP UNIT. - AUTH#VSA1RJ0018 TOTAL $576.25 - REPLACED CD PLAYER ASSEMBLY 860451 .50 T172 T299 CD PLAYER WAS NOT WORKING
Lexus of Rockville Centre 43918 0613644 DISTRIBUTOR/HDLIGHT/T. SGNL C/S ONE DASH LIGHT IS ON??,PLEASE CHECK AND REPORT. - REPLACED P/S REAR TAIL LIGHT ASSEMBLY
Dealer Reported 12/17/2008
Lexus of Rockville Centre 43917 0611274 ACCESSORY CUST STS THE CD CHAGER INOP SOP CHANGER. - REORDER CD PLAYER REINSTALLED CD PLAYER ON 01/28/2009 RO#613644 SEE RO FOR INFORMATION.
Lexus of Rockville Centre 43917 0611274 TENTATIVE APPT. WE HAVE MADE A TENTATIVE APPOINTMENT FOR YOU 6 MONTHS FROM TODAY. OUR APPOINTMENT DESK WILL CONTACT YOU ONE WEEK PRIOR TO YOUR DATE TO SCHEDULE AN APPOINTMENT AT YOUR CONVENIENCE. - TENT APPT - TENT APPT
Dealer Reported 10/17/2008
Lexus of Rockville Centre 42544 0606968 45,000 MILE SERVICE REPLACE ENGINE OIL AND FILTER ROTATE TIRES REPLACE WIPER INSERTS REPLACE ENGINE AIR FILTER REPLACE P.C.V. VALVE CLEAN AND ADJUST EMERGENCY BRAKE INSPECT DRIVE SHAFT BOOTS INSPECT AND TOP OFF ALL FLUIDS (IF APPLICABLE) RESET OIL REMINDER LIGHT INSPECT AND - 45,000 MILE SERVICE - 45,000 MILE SERVICE.
Lexus of Rockville Centre 42544 0606968 ACCESSORY CUST STS THE DVD PLAYER WILL NOT WORK. WILL NOT CLOSE WHEN DVD IS INSERTED. - CD PLAYER ORDERED AND PAID FOR. EXT WARR AUTH VSC - 1QD3586 AMOUNT OF $1060.49
Lexus of Rockville Centre 42544 0606968 FRONT/REAR BODY CUST STS THE P/S DOOR WILL NOT CLOSE WHEN THE REMOTE IS PRESSED. - REPLAECD P/S FRONT DOOR LOCK ACTUDACTOR ASSEMBLY WAS NOT WOR WHEN CAR SIN ON PARK ALL THE LIGHTS ARE FLASHING DASH BUT THERE IS AFTER MARKET WIRE AND REMOTED BY D/S FRO DOOR BY KIP PANEL
Lexus of Rockville Centre 42544 0606968 TENTATIVE APPT. WE HAVE MADE A TENTATIVE APPOINTMENT FOR YOU 6 MONTHS FROM TODAY. OUR APPOINTMENT DESK WILL CONTACT YOU ONE WEEK PRIOR TO YOUR DATE TO SCHEDULE AN APPOINTMENT AT YOUR CONVENIENCE. - TENT APPT - TENT APPT
Lexus of Rockville Centre 42544 0606968 25 POINT CHECK CUSTOMER AUTHORIZES COMPLIMENTARY 25 POINT SAFETY INSPECTION - 25 POINT CHECK - 25 POINT CHECK
Lexus of Rockville Centre 42544 0606968 NON WARRANTABLE OPERATION CODE CUST AUTH FRONT DIFF SERVICE - PERFORMED FRONT TRANSFARE CASE SERVICE
Lexus of Rockville Centre 42544 0606968 NON WARRANTABLE OPERATION CODE CUST AUTH REAR DIFF SERVICE - PERFROEMD REAR DIFF SERVICE
Lexus of Rockville Centre 42544 0606968 NON WARRANTABLE OPERATION CODE CUST AUTH TRANSFER CASE SERVICE. - PERFRME FRONT TRASNFARE CASE SERVICED
Lexus of Rockville Centre 42544 0606968 BRAKE FLUSH CUST AUTH BRAKE FLUSH - PERFORMED BRAKE FLUSH
Lexus of Rockville Centre 42544 0606968 SUBLET WORK 1 DAY RENTAL
Dealer Reported 04/30/2008
Lexus of Rockville Centre 38698 0294439 NYSI W/ EMISSIONS CUSTOMER REQUESTS NYSI WITH EMISSIONS. - INSPECTION DUE. - NYSI COMPLETE
Dealer Reported 01/09/2008
Lexus of Rockville Centre 36384 0286374 STEERING WHL/MAIN SHAFT CUSTOMER STATES STERRING WHEEL IS OFF CENTER CHECK AND REPORT - PERFORMED WHEEL ALIGNMENT RESET VGRS
Lexus of Rockville Centre 36384 0286374 25000 MILE SERVICE NON WARRANTYNON OEM - REPLACE ENGINE OIL & FILTER, ROTATE TIRES, INSPECT WIPER BLADES, INSPECT BATTERY & CONNECTIONS, LUBE HINGES. CHECK & REPLENISH ALL FLUID LEVELS. INSPECT AIR FILTER. CHECK ALL INSTRUMENTS, ACCESSORIES & LIGHTS. CHECK TIRE WEAR & RESET TIRE PRESSURE. ROAD T - ============================= ======================== - PERFORMED 35,000 MILE SERVICE
Lexus of Rockville Centre 36384 0286374 WHEELS & TIRES CUSTOMER REQUESTS QUOTE TO REPLACE TIRES - RECOMMEND TO REPLACE ALL 4 TIRES - SUPPLIED, MOUNTED AND BALANCED 4 NEW TIRES FOR VEHICLE
Lexus of Rockville Centre 36384 0286374 OTHERS PERFORM FUEL INJECTION SERVICE - PERFORMED FUEL INJECTION SERVICE
Lexus of Rockville Centre 36384 0286374 OTHERS CHECK FOR MISSING FRON BRAKE ANTI - RATTLE SPRINGS - ANTI RATTLE SPRINGS MISSING FROM FRONT BRAKE PADS - REPLACED ANTI RATTLE SPRINGS FOR FRONT BRAKE PADS
Dealer Reported 06/27/2007
Lexus of Massapequa 31692 0134345 30,000 MILE SERVICE REPLACE ENGINE OIL AND OIL FILTER ROAD TEST ROTATE TIRES REPLACE A/C FILTER LUBRICATE AXLE SHAFT, RE - TORQUE BOLTS INSPECTION 1: BALL JOINTS AND DUST COVERS, BODY, BRAKE LINES AND HOSES, BRAKE PADS AND ROTORS, AXLE SHAFT BOOTS, EXHAUST PIPES AND MOUNTINGS, - 30K SERVICED
Dealer Reported 03/07/2007
Lexus of Massapequa 25654 0125940 25,000 MILE SERVICE REPLACE ENGINE OIL AND OIL FILTER ROAD TEST ROTATE TIRES - COMPLETED
Lexus of Massapequa 25654 0125940 INSPECT BATTERY CHARGE LEVEL CK BATTERY - CRANKS VERY SLOW - CK AND ADV - CHECK ELECTRICAL SYSTEM AND BATTERY - REPLACE BATTERY
Lexus of Massapequa 25654 0125940 NON WARRANTABLE OPERATION CODE REPLACE AIR FILTER - COMPLETED
Dealer Reported 04/06/2006
Lexus of Massapequa 19932 0101760 NYS EMISSION INSPECT NYSI EMISSION INSPECTION - REQUIRED - COMPLETED
Lexus of Massapequa 19932 0101760 STEERING WHL/MAIN SHAFT C/S STEERING WHEEL NOT CENTERED - OUT OF ADJUSTRMENT - SET VGSR WITH COMPUTER.
Lexus of Massapequa 19932 0101760 NAVIGATION COMPUTER C/S NAV SYSTEM NOT WORKING PROPERLY...CHK AREA - IN WRONG AREA - RECALAIBRATED GPS OPERATING AS DESIGNED
Dealer Reported 04/05/2006
Lexus of Massapequa 19943 0101823 FRONT AXLE C/S VEH IS HIGH IN FRONT...CHK HGT SENSORS - RIGHT FRONT HIGHT SENSOR HAS TROUBLE CODE#C1711 FR HEIGHT CONTROL SENSOR CIRCUIT MALFUNCTION. - REPLACED RIGHT FRONT HIEGHT CONTROL SENSOR.
Lexus of Massapequa 19943 0101823 STEERING WHL/MAIN SHAFT C/S STEERING WHEEL OFF CENTER - IN RELATION TO JOB #1 - CENTERED STEERING WHEEL
Dealer Reported 02/15/2006
Lexus of Massapequa 18622 0098383 25000 MILE SERVICE NON WARRANTYNON OEM - REPLACE ENGINE OIL & FILTER, ROTATE TIRES, INSPECT WIPER BLADES, INSPECT BATTERY & CONNECTIONS, LUBE HINGES. CHECK & REPLENISH ALL FLUID LEVELS. INSPECT AIR FILTER. CHECK ALL INSTRUMENTS, ACCESSORIES & LIGHTS. CHECK TIRE WEAR & RESET TIRE PRESSURE. ROAD T - ============================= ======================== - 20K SERVICED
Lexus of Massapequa 18622 0098383 OTHERS CLIENT STATES THE VEHICLE WILL BE LOUDER FIRST THING IN THE AM WHEN STARTING - NO PROBLEM FOUND COULD BE NORMAL CONDTION SENSE IDLE IS HIGHER IN THE MORNING
Lexus of Massapequa 18622 0098383 EMMISION SVC $152.75 PERFORM EMISSION CLEANER - DONE
Lexus of Massapequa 18622 0098383 SPECIAL ORDER PART REAR DECK COVER CAME APART PLASTIC PIECE ON REAR DOOR IS COMING LOOSE - WEAK RETENTION , RETAINER SEPARATED - REPLACE PANEL
Lexus of Massapequa 18622 0098383 DAYTIME RUNNING LTS INSTALL THE DRL RESISTER AND WIRE HARNESS (APPLICATE TO ONLY 1998 - 2002 MODEL YEARS) - INSTALLED DRL RESISTER WIRE HARNESS AND WIRE TO FUSE BOX
Dealer Reported 08/25/2005
Lexus of Massapequa 14819 0085643 ACCESSORY CLIENT STATES COMPARTMENT IN DASH BELOW RADIO DOES NOT OPEN WHEN PUSHING IN - DOLAR BILLS WERE STOCK IN IT
Lexus of Massapequa 14819 0085643 ACCESSORY CLIENT STATES THERE IS A PLASTIC COVER ON THE PASSENGER SIDE IN REAR OF VEHICLE THAT IS MISSING. - ORDERED PART
Lexus of Massapequa 14819 0085643 ACCESSORY CLIENT STATES THERE IS A CLIP BY THE REAR TAILGATE ON THE DRIVER SIDE THAT DOES NOT STAY IN PLACE - SECURED JACK COVER
Lexus of Massapequa 14819 0085643 FRONT/REAR BODY CLIENT REQUESTS AN ESTIMATE TO REPAIR DAMAGE TO TH THE PASSENGER REAR OF VEHICLE PRICE ON TAIL LAMP ETC - DANNY
Lexus of Massapequa 14819 0085643 NON WARRANTABLE OPERATION CODE CUSTOMER REQUEST LUBE OIL & FILTER CHANGE. CHECK ALL FLUID LEVELS. - COMPLETED SERVICE COMPLIMENTARY FIRST LOF DUE FROM SALES, WAS SOLD AS CERTIFIED BUT PUT THROUGH WITH PLATINUM WARRANTY.
Dealer Reported 06/01/2005
Lexus of Massapequa 12021 0078899 NON WARRANTABLE OPERATION CODE SHMUEL BRODSKY: REPAIRED WINDSHIELD. INV #333517
Lexus of Massapequa 12021 0078899 DYNASTY DETAILING FULL DETAIL AND TOUCH - UP. INV #2353
Dealer Reported 05/06/2005
Lexus of Massapequa 12019 0077076 AUTOQUAL CLEANED RUGS. INV #2036E
Dealer Reported 04/26/2005
Lexus of Massapequa 11994 0074785 ACCESSORY ADD R/ENT.DVD MONITOR,LICC TO INSTALL ADD LOJACK CONTROL # BA 104 - NEVER RECEIVED BILL FOR LOJACK
Dealer Reported 04/15/2005
Lexus of Massapequa 12018 0075393 MISC CLIENT STATES MULTI DISPLAY INOP. CHARGE BACK TO CUSTOM COACH WORKS - CHECKED CAR FOUND THE INSTALL TO THE REAR DROP DOWN SCREEN FOUND OPEN WIRE GROUNDING OUT SYSTEM REMOVED POWER HOOK UP - EVERYTHING WORKS GOOD CALLED CUSTOM COACH WORKS TO REDO INSTALL PROPARLY
Dealer Reported 04/07/2005
Lexus of Massapequa 11997 0074838 CERTIFIED PREOWNED PDI - PERFORM PRE - OWNED CERTIFICATION - CERTIFIED - COMPLETED
Lexus of Massapequa 11997 0074838 NYS EMISSION INSPECT NYSI EMISSION INSPECTION - REQUIRED INSP # 2597460 - COMPLETED
Lexus of Massapequa 11997 0074838 AIR CLEANER - REPLACED AIR FILTER - COMPLETED
Lexus of Massapequa 11997 0074838 REPLACE WIPER INSERT - REPLACED WIPER INSERTS - COMPLETED
Lexus of Massapequa 11997 0074838 NON WARRANTABLE OPERATION CODE - DRAINED AND FILLED TRANS FLUID - COMPLETED
Lexus of Massapequa 11997 0074838 NON WARRANTABLE OPERATION CODE - ROTATED AND BALANCED ALL 4 TIRES - COMPLETED'
Lexus of Massapequa 11997 0074838 OTHERS R&R FRONT AND REAR BRAKES PAINT ROTORS - R&R FRONT AND REAR BRAKES PAINTED ROTORS AND CALIPERS RESURFACED ROTORS - COMPLETED
