ARCHIVE NOS Genuine ASMO OEM Japan Spec. 12V Cold Spec. SNOW VERSION package Wiper Motor in original parts box 📦 85120-90804
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
Here we are and here we go …
I have personally owned this since new date on parts box sticker
I am doing a major store inventory and all that Jazz …
And there this little BABY ASMO was in zip lock Bag full climate control zero humidity off the floor …
I will do a full function bench test video short here shortly …
Mounting hardware included of course as always ….
+Fully insured USPS lower 48 shipping
or
+UPS fully insured to the
great white NORTH only ….
$654.32
Replaces the Below part #.s
85120-90310 , 85120-90308 , 85120-90802
85120-90804MOTOR AND BRACKET ASSY, WINDSHIELD WIPER
85120-90308FOR 12V1
85120-90310ARCTIC
85120-90310COLD SPEC
mm
What makes it different than the rest of them?
well .......it is 12V
not 24V
- microfiche says COLD SPEC.
- more copper windings
- it Does weigh more on a MED postage scale by a notable amount , thicker metal shell
- rubber water seals
- thicker blue wires on motor
- it has the UPDATED black wire dedicated polarized ground tab Ring Terminal wire
the metal gearing inside NOT Gulf States warm climate plastic white ones
see ........
back in the day ANY lower 48 states that Border CANADA = COLD SPEC .....+ ALASKA too of course
alternators and starters fall under this catigory .....
you follow the TECH here ...?
if anyone has anything on paper Print Original TOYOTA media to add ?
Bring it on !
thanks
matt
i added factory microfiche TECH up top , it will help add to what i know here
thanks
Below is my HEAVY DUTY Parts Applied : SNOW VERSION Upgrade Late model washer Bottle / coolant over flow ....
- i install a section of OEM DENSO EPDM Rubber Suction Hose to the bottom side , overflow cap inside the bottle , this is both Freeze-Proof , and High-Heat rated to exceed Boiling water Temp. as well
- the washer cap is the HJ61 series EU Spec. Cold Climate Spec, hard-shell part # , this will NOT bend or loose its keeper like the soft oem one that comes with the bottle , i replace it with the Best
DENSO Japan has to offer
- i install the cold-spec, / Heavy Duty OEM
ASMO made in Japan Spec. washer fluid pump motor , with marine grade stainless steel P2 JIS Vessel screws of course .....
- the qty x 3pcs OEM #8 mark head JIS DOUBLE SEMS mounting hardware to fender black bracket bolts are a modern age 2025 LEAP IN surface treatment and metallurgy not to be overlooked :idea:
- lastly , when it comes to the reproduction OEM
WASHER & COOLANT Decals icing on the NipponDenso final fit form and function cake ... i don't hold back .....
note : make sure to TURN ON AUDIO SOUND Speaker ICON ! it will better help explain WHY HEAVY DUTY TOUGH as NAILS = SNOW VERSION
That's really cool. You have any of the "normal" wiper motors for the 77-82's?
is this considered the smaller ones that use a smaller sheet metal cover ?
