Hey all - Since my last post I was able to get the CDff and lockers working, however 2 month later I ran into this issue...
I posted this in 80-Tech forum, but thought I would post it here as well...
What I have - 96 TLC FZJ80, Factory Lockers, and 7PIN Mod CDiff Switch
History -
CDiff would not engage in 4L
I recently replaced the CDiff switch and it started to work properly when in 4L, disengage in 4H
I installed the CDiff Switch but didn't do the 7PIN Mod
Drove the TLC for <500 Miles without issue, until the issue stated below started this week.
** Keep in mind Flickering and Flashing are not the same, this issue is Flickering **
Issue -
While driving the ABS / CDiff lights came on with the CDff light flickering
I pulled over, turned off the TLC, restarted but had the same reuslts
I drove it home <5 Miles, no wheels chirping and it didn't seem like the CDff was engaged
While driving the CDiff Light will flicker sometimes going to solid
ABS Light will come on and off but not flicker
What I've done in this Order -
Removed the connector to the CDiff Switch and turned on the TLC - No change
Short the CDiff Switch Connector, try in 4H and 4L, power on / off, backup, go forward - No Change
Complete the 7PIN Mod for CDiff, turn on TLC, try in 4H and 4L with/without the CDiff Switch enabled, power on / off, backup, go forward - No Change
Drive it in Figure 8's in 4L on dirt - No Change
Results -
So far not matter what I've tried I still get the same result -- ABS and CDff Light On with a little flicker
Next Steps -
I'm thinking maybe this is a short due to the fact that I've disconnect the CDiff Switch and the lights still come on.
Anyone have any other suggestions?
