For Sale Northern Virginia; Unknown year M416 Overlanding trailer, titled and licensed.
M416 trailer. Equipped with a removable insert for camping, included in the sale are the four tailer tongue jacks that allow you to remove the insert and use the trailer as a cargo carrier. I have sold the roof top tent but you can add your own easily. There is a 16 gallon water tank on board with 12 volt pump, on board battery that can be set up to charger through the 7 pin trailer connection or through the anderson plug, propane fired on demand water heater housed in a never been used 1968 USMC jerry can, pull out rear with space for a stove and storage. The insert is constructed of 1" square steel tube frame with plywood sheathing. Some of the plywood is in need of replacing. This has been a great trailer, but we have a tear drop on order and this one has to go. It has LED tail lights with reverse lights, ground lighting on a separate switch, camp lights on the front and rear as well as the right side, all separately switched. Diamond plate steel fenders are easily strong enough to stand on, there are also rock rails in front and behind the fenders. There is a 20 gallon propane cylinder mount on the right side. The "house" battery is mounted on the tongue on the left side. There is the factory "parking brake" in it's original location and is fully functional. Also, there are two jacks on the rear corners as well as the tongue jack that make leveling the trailer at your campsite a breeze using the attached levels on the insert. The switch panel has several unused switches so you can add additional accessories as you see fit. Included in the sale is the pintle hitch that slides into a regular 2" receiver hitch. The trailer has a lunette (standard military issue), this is crazy strong and allows the tailer to articulate unimpeded. We towed this out to Colorado two years ago and it performed very well being towed behind my 2005 Jeep LJ. $2,200, will consider other offers.
