SOLD Northern CA: 6l80e trans NP203 and split case
Stafford, VA
I have a 6l80 trans, I got it used and it worked well for me but I pulled it to put a 6l90 in for a different transfer case setup. When it was out I upgraded the pump to the newest GM part, I also updated the valve body to 2010, so you need a 2010 or newer computer to use as is. Trans by itself is $1000. I can also include a full rebuild kit with valve body upgrade but it's fine as is. I am clearing out parts for a move.
The NP203 and split case were attached to this trans. I rebuilt the NP203 and resealed the split case. Will come with the rest of a rebuild kit. No shifters though. NP203 has a 32-spline input currently and I have a 27-spline also. $1000 for both transfer cases and the adapter plate on the front of the NP203.
I can supply and unlocked E38 ECU matched to this trans for $200...I'll program it for whatever engine you have, as long as it's a 58x. Older 24x engines and computers will not work with a 6l80.
No, I will not ship them. I will help with Mud Ship though. I can deliver within 200mi if you pay for gas.
how'd the 203 work for you? mine howls like crazy. I really like that NWF plate you have on there, it's too bad mine is set up for dodge pattern, or id buy your whole setup just to have a complete spare setup located for my next cross country trip.
My NP203 was pretty quiet but it would never shift into low, that's why I rebuilt it. I should put this setup back in my truck because the Black box I replaced it with is noisy and leaks...I hate it. I completely rebuilt a 6L90 and I want to keep that so I'm stuck with the Blackbox.
For anyone else curious this should bolt up to a 4L80 with the OEM GM 6-bolt transfer case adapter. Or you could probably remove the North West Fab adapter plate and drill the NP203 face for whatever pattern.
Interested in the 203 and split case,. Sent a pm
