- Year
- 2006
- Vehicle Model
- LX470
- Location
- Array
- Mileage
- 216800
- Color
- rgb(108, 99, 99)
$17,000. I've been back and forth about selling this, but the time has finally come. This is a 2006 LX in galactic gray mica with gray leather interior. I bought the truck from a Mercedes dealer in Atlanta, GA in March 2019 with 165K miles. It was traded in by the original owner who had it in Atlanta since he purchased it. At the time, I had been searching quite awhile and jumped on this one immediately after seeing that it was serviced by a Lexus dealer its entire life and came with impeccable service records. it drives like a dream. I truly think you will be hard-pressed to find another 100 series LX or LC with 200K + miles in this good of condition. All maintenance is up to date (see below). It's been in GA and NC its entire life. I have the title in hand.
216,800 miles
VIN: JTJHT00W464012116
190K service complete - timing belt, water pump, hose, pulleys, idlers, fan bracket, thermostat, Alignment, coolant flush, shaft, retorque bolt, transmission drain (more service listed below)
AHC works flawlessly
I removed the running boards. I still have them if the buyer wants them.
Tires have 16K miles on them. I'm running Cooper Discover A/T 275/70/18.
There are the normal nicks and scratches you'll find on a 2006 vehicle.
It's pretty much stock, but I added the following:
BT45-TOY bluetooth with microphone
Weathertech mats and rear cargo liner
LED interior lights and headlights
Rims are painted with plastidip which can be removed easily (I've included pictures before paint)
Cons
Original hood and side view mirror clear bra is weathered and cracked, but still serves its purpose so I have kept it place
Original owner spilled a little white paint in back. There are some slight signs if you look closely, but it's mostly under rear driver side 3rd row seat and a few drops on rear bumper.
Driver seat shows wear on leather and there is a 1" and 1/2" opening next to seam.
2nd row console drink holder assembly does not work.
TPMS light is on (pretty common issue). When I installed new tires at 200K the light came on and has something to do with tire stems they used. I put black tape over it on dash and it's nearly invisible.
Plastic piece around license plate has some bubbles
Here's a maintenance history that I keep on a spreadsheet. I pieced it together the best I could when I bought it and then kept it updated with service I had done.
More pictures on Facebook link.
216,800 miles
Cons
Date | Mileage | Service |
6/19/2008 | 35,537 | front brakes, turn rotors |
3/31/2010 | 50,327 | battery |
7/6/2010 | 53,248 | rear brakes |
2/16/2011 | 60,756 | 60K service, lubricate shaft, retorque bolts, replace brake fluid |
2/7/2012 | 70,366 | front brakes, turn rotors |
7/17/2012 | 75,889 | battery, |
10/1/2012 | 80,436 | 80K service, alternator, |
8/16/2013 | 92,895 | 90K service, tIming belt, water pump, A/C filter and flush, new font C/V axle boots, lubricate shaft, retorque bolt, |
6/4/2014 | 103,347 | front brakes, turn rotors |
6/5/2015 | 120,300 | clean throttle body, lubricate shaft, retorque bolt, REPACK WHEEL bearings, replace brake fluid, replace spark plugs |
2/5/2016 | 130,026 | front brakes, turn rotors |
8/9/2017 | 148,621 | differential service, |
4/5/2018 | 155,817 | 150K service, front brakes, turn rotors, clean throttle body, lubricate shaft, retorque bolt, REPACk wheel bearing, replace engine coolant |
8/28/2018 | 162,100 | replace T-fitting |
11/19/2018 | 163,340 | secondary air pump and valves replaced |
3/4/2019 | 166,160 | switch inhibitor replaced |
3/6/2019 | 166,681 | 4 tire balance and alignment |
5/21/2019 | 170,000 | windshield replacement |
7/3/2019 | 171,217 | Oil change |
175,500 | Oil change | |
1/7/2020 | 180,142 | Oil change |
1/9/2020 | 180,200 | new battery (Advanced) |
5/21/2020 | 185,385 | Oil change |
9/15/2020 | 189,850 | Oil change |
10/2/2020 | 190,000 | timing belt, water pump, hose, pulleys, idlers, fan bracket, thermostat, Alignment, coolant flush, shaft, retorque bolt, transmission drain |
10/8/2022 | 190,800 | rear brakes, repack front wheel bearings |
195,000 | Oil change | |
5/7/2021 | 199,500 | New A/C compressor and clutch |
199,000 | Oil change | |
200,000 | new tires | |
8/10/2021 | 203,000 | Oil Change |
12/13/2021 | 207,000 | Oil Change |
12/23/2021 | 207,800 | front and rear differential and transmission service, front brake, rotate tires, RADIATOR |
1/20/2022 | 208,000 | CV axles, valve cover gasket, |
2/21/2022 | 208,500 | upper control arms, 1 lower control arm, ball joints |
3/8/2022 | 209,500 | ball joints |
4/12/2022 | 211,764 | Oil change |
5/1/2022 | 212,500 | recharge A/C - freeon |
8/16/2022 | 216,000 | Oil change |
