Hi all,
First I'd like to preface my question/request by saying that I've performed searches in this GXOR forum as well as the broader forums but couldn't find info. It could be that I am not using the Search function correctly or very well, but for what its worth, I searched prior to asking
Does anyone have the GX470 OEM suspension specifications or know where I can find them? I'm particularly interested in the length/dimension of the shocks/struts in fully compressed, "nominal" (under "normal load/weight" of car) and fully extended.
In case anyone is wondering why I want this info: I'm trying to find out; if the OEM and OMEmu shocks are the same length at full extension or if the OME is longer at full extension.
I just bought a 2007 GX470 with OMEmu (not to be confused with OEM) "2 in" lift, medium load variant, it has the OEM UCA, LCA and bump stops (Gen3 4Runner Spring guids/upper perch for the Bladder delete), with 285/70R17 size tires and no KDSS. I have the specs for the OMEmu shocks/struts but can't tell if they are longer, the same or shorter than the GX470 factory shocks/struts because I can't find the data/specs.
Thanks in advance,
Gerald
Thanks in advance,
Gerald
