non nav harness parts list.
Al.
I was going to write this out, it's just taken me a while to do it. But here it is. Notes at the bottom.
Please don't talk about other parts here. I just want to get this out.
*newark electronics for out of stock items is my go to as of late. Mouser continues to have supply issues and a ton of backordered items.
UPPER
M5 female (1) 571-1376360-1 mouser
M5 male (1) 571-1376357-3 mouser
M9 for LC or M12 for LX female (1) 571-1318221-1 mouser nexus electronics minimum order 10 edit ALIBABA 10.17.23
A47 toyota repair wire (1) 82998-12640 toyota counter
M5 power terminals (2.3 variety) quantity-6 #7116-4020 nexus electronics
M9 or M12 terminals quantity-11 #571-316837-2 mouser
A45 terminals quantity-2 for M5 female 571-1123343-1 mouser
35mm shrink tube.
LOWER
C28 male (1) 571-1376103-1 mouser
C28 male terminals quantity-10 #571-1376109-1 mouser
A45 female (2) 571-1318389-1 mouser
A45 male (1) 571-1376113-2 mouser
A45 terminals quantity-50 #571-1123343-1 mouser
40mm shrink tube
Glue gun , electrical grade silicone
¼” tubing
11 colors 22 gauge crosslink. Delcity, wirebarn. There are a few different grades. It has to do with insulation thickness. TXL is what I use, it's the only one available in 22 awg.
ebay 1026 CT CRIMP TOOL (sargent quality tools) Mouser recommends this model. It’s cheap and works well for all of these terminals listed.
*There are minimum orders at certain places, some of these won’t be in stock. I've ordered from mouser, that digi place, nexus electronics, onlinecomponents, delcity, wirebarn, and maybe some others.
It's getting difficult to find the toyota repair wire at dealers. They have raised the price of that wire to $38. Call a discount place like mcgeorge to check USA inventory. Anytime you order one online and the order gets cancelled immediately after you place it it means there aren't any available or that the number that you ordered isn't available. Then you must call some dealers to check.
The M9 terminal will fit inside the A47, it's just not the same type and will work fine. I have always supplied the real IDC terminal repair wire at $25 I have a hard time sticking a non uniform terminal in there.
Buy extra terminals, you will waste quite a few.
M9, M5 male are hard to find sometimes. The female M5 are only available in the same configurations as they are on the AC amp circuit board, at least as far as I could find. You snip these off to the appropriate length, and stick them into the backside of a female to make an adapter. You get the idea. that applies to both male housings, A45 and M5.
This is not a for sale thread.
pictured is the jan2006-07 version. See the purple and blue two wires coming out of the C28 into the A45 on the left hand side of the A45.
All other versions don't have this. All years, all models are the same regarding wiring except jan06-07 have these two wires.
Thanks for this and for your willingness to help answer any questions regarding the navigation delete.
