Here's recent things I've done none of which have helped the problem. I need some ideas of where to look next. Valve adjustment, Replaced TPS and AFM due to error codes in CPU, Air Filter replaced, spark plug wires, distributor cap, rotor, spark plugs, fuel filter, checked timing. New exhaust system and new cats. I tested compression on the engine and got 150, 148, 150, 150, 139, 151.
I have a slight stumble at 2k rpms in 3rd gear (Have H55f). Lack of power most noticeable when trying to accelerate from stand still rather than on the freeway. Engine revs fine but no power...The hotter it is outside the worse the acceleration seems, but that could be due to the fan clutch being on and a/c running which accentuates the underlying problem...
I briefly had a 2.5" exhaust from manifold back and with that set up, I gained more power above 2.5k rpms. But low rpm power still was marginal. After 2.5k, it felt like a turbo kicked in and I could accelerate better. However, I returned to stock exhaust layout. No power throughout rpm band now, worse at low RPMs i believe.
Can someone who is knowledgeable recommend where I should be looking at next to identify and correct the problem?
