the story so far... glow plug indicator spontaneoulsly disentegrated last week at the mountain, and blew black fusible link at left (drivers) side battery. i jumped both connections and was able to get it started and drove home. the next day i tried the same thing and it started and ran so i let it warm up, but came back out to find it had stalled. have since discovered that glow plugs are working well(20.5 v at the bus bar and all plugs ohm out well, visually checked and they get red hot) but there is no fuel at the inlet to primer. working back along the line i found what i think to be the low pressure transfer pump on the left frame rail behind the vaccuum reservoir for power brakes. it looks like a pump with an inlet and outlet and two wires running into the top. the line from the tank has lots of fuel but i think the pump is not running. checked voltage on a green with white stripe wire and found .7 v when cranking.
so, does anyone know how this pump receives power? what should the voltage be and when should it be there(run and crank)? if this is tied into the edic function i have seen that the motor works well, moving the pump through crank, run and stop.
hope you can help,
chris
hope you can help,
chris
