Green coolant is fine, radiator should be full, the recovery tank level to the full line.
Remove radiator cap (when cold) and fill to the brim. Put cap back on. Fill overflow to full mark.
Check again in a few days, check each week. Check for leaks at the various hoses - eg at the heater valve, the PHH and the other PHH (throttle body bypass hose) on the USDS block. Search will find you the details.
If the coolant is a few years old, then it makes sense to drain & refill with new. Coolant loses it's corrosion protection properties over time.
I presume you are new to vehicles? Consider the coolant in your vehicle as the equivalent of keeping your body hydrated...
cheers,
george.
As other members have said this is a great time to do a flush and refill. But first thing first, you need to make sure you don't have any leaks, so you'll need to find out where that coolant went, because coolant doesn't just evaporate on it's own. Just in case you don't know this, when you do a radiator flush, and refill you need to use distilled water, NEVER USE WATER FROM YOUR GARDEN HOSE! Buy about 6 to 8 gallons of distilled water to use for your flush, plus 2 gallons of 100% Preston green. An even better idea, since you don't know when your radiator was last serviced, would be to replace it with a new one, or have it cleaned at a radiator shop. While your at it, replace the thermostat, get a new radiator cap, plus a new water pump.
Thanks a lot for the help everyone. I have never serviced the radiator but I filled it up with the same green 50/50 that was in there and everything seems to be good. I will run a flush soon and watch the levels.
At work so not sure if anything is in overflow and will check tonight.
I don't see any leaks and have never had any cooling issues, but I was able to fill a little less than half my jug?
Just in case, although I may be reading you wrong here, but to clarify, when you filled the radiator, you should also fill the overflow tank to the MIN level, it should not be dry. You need enough coolant so that it will siphon back and forth between the radiator and the tank. Do NOT count on the radiator to fill the overflow. If it does that, you'll be short in the radiator. The idea is to keep the system full of coolant and avoid and purge any air from it.
My bad, I appreciate the help. I've been working all day so just now able to thoroughly read haha.I had mentioned at the top of the thread, FILL the radiator and FILL the overflow/coolant bottle to the FULL mark (there is a mark - do NOT fill the bottle to the brim)
Must read instructions better
cheers,
george.
Brockdeck, A word of warning since you may be new to the Land Cruiser. The factory temp gauge on these trucks can move from the middle of the gauge (normal 185 degrees) to the red mark (HOT 240 degrees) really, really FAST. Over heating the engine on these trucks is not a good idea for the long term health of it's head gasket. So one of the best things you could do since your truck is OBD2, is buy a scan gauge for it, that way you'll no longer have to rely on the factory gauge.
It hooks to your OBD2 plug in the dash.
https://www.scangauge.com/
You wrote "Luckily for me I've never seen that thing move from the middle of the gauge if not the smallest amount higher than that"
But when it does move from the middle to the red because of over heating it does it in a blink of an eye!
