Hello folks. I have a question about the brake system on my 1994 FZJ-80. On my way home from work Friday I noticed the brake pedal traveling a bit farther toward the floor each time I'd use it, until it was actually bottoming out with no braking whatsoever!
Luckily I was close to home so I used the e-brake and got it home. I was away for the weekend and got a chance to look at it again today. Strangely enough the brakes were fine this morning when I fired it up and drove it up and down the driveway. I'm not planning on driving it but found that to be a little strange. It was much cooler this morning then when the problem occurred on Friday. I checked the fluid reservoir and it's full. Does this sound like bad master cylinder?
I priced new master cylinders as well as master cylinder rebuild kits today and would like go the rebuild route. Does anyone know how involved installing a rebuild kit is? Any special tools required?
Many thanks for any help...
Ted
Ted
