1980 FJ40 that has no break lights. I'm not 100% sure but I think they worked a month or so ago when I installed the wiring harness. Brake pedal was in then but no fluid, etc., but I'm pretty sure I tested the depth of the brake switch back then.
Anyway, now I have brakes, but no brake lights. The bulbs appear to be fine. I've removed the switch.
1. How do I test the switch? Is there anyway to bypass it to prove that the switch is the problem?
2. Where should I have power? At wiring harness where the switch plugs in? And at the brake lights?
thanks.
thanks.
