SOLD NM Refurbished Early 2F Distributor - Converted to Vacuum Advance with New NipponDenso Advancer
4Cruisers
I refurbished and modified this '76 2F vacuum retard distributor (19100-61020) to convert it to vacuum advance, using a new NipponDenso advancer. The distributor is now basically the same as an 08/76 through 09/77 distributor (19100-61021). The advancer's vacuum advance curve is very similar to the curve for the advancers Toyota used in 08/76 through 09/77 2F distributors - advance begins at 3.94" Hg (100mm Hg), the same as the NLA 2F advancer (Part Number 19220-61020). The vacuum advance upper stop limit was set to limit the vacuum advance to ~10 degrees distributor advance. Besides the advancer, other new NipponDenso parts include the distributor cap, distributor cap clamps, rotor, points, points damper, points shield, mechanical advance weights with sleeves, terminal, O-ring, cam grease plug, wire clamp, and all hardware.
$175 shipped via USPS Priority Mail.
I am looking for one of the green electrical connectors in above pics to repair my pigtail for my 77 distributor You don't have any you would sell? My harness is pristine and I don't want to modify by changing connectors. Could really use your help?
Like this? I have more than 20 new NipponDenso terminals that I haven't yet posted in the For Sale forum, for this one I swapped out the connector for the type you're looking for (the connector housing itself is used, but in good shape).
