SOLD NM Hybrid Small Cap Distributor - Equivalent to the Non-US 19100-61080 Distributor
4Cruisers
Refurbished small cap Land Cruiser distributor equivalent to the popular non-US 19100-61080 points distributor. $195 shipped.
Here are the technical details:
- New parts from non-Land Cruiser Toyota distributors include the points cam, later type OEM upper breaker plate parts and points, external condenser, octane selector knob/cap/sleeve/gasket, wire harness clip, distributor cap clamps, mechanical advance weights, and miscellaneous hardware.
- F engine distributor cap and rotor are new Toyota parts.
- Distributor housing and vacuum advancer are from an aftermarket electronic distributor.
- Distributor shaft, gear, mechanical advance springs, and lower breaker plate are from a later F engine vacuum retard distributor.
- Distributor shaft O-ring is a new generic part.
- Distributor shaft thrust play was adjusted to FSM specifications using a new phenolic washer.
- No discernible distributor shaft lateral play.
This refurbished distributor will be an excellent high quality alternative to the non-US 19100-61080 small cap distributor.
