4Cruisers
Refurbished '81 through '87 big cap distributors set up with ignition points, for installation in pre-electronic ignition Land Cruisers. Provides the advantages of a bearing supported shaft and sealed cap, without the need for an igniter. Does require a dented side cover. Can be set up with Pertronix electronic ignition if desired. A detailed write-up with all pertinent technical information can be found here:
forum.ih8mud.com
$195 shipped.
Distributor Tech - Points Distributor with Shaft Bearing and Weatherproof/Vented Cap
I just finished refurbishing and modifying an 8/80 and later big cap 2F distributor for a fellow MUD member's '74 FJ40. We decided to try building a points distributor using an FJ60 electronic distributor - @ToyotaMatt's "Skunk Works" mentality is taking a firm hold in my shop. This modification...
$195 shipped.
