SOLD NJ: 2005 Lexus LX470 - Built - 13.5k
Year
2005
  1. LX470
Mileage
255000
Color
Gray
I'm switching over to a 200 series and need to fund it. Lots of good maintenance and good mods. Thank you for your consideration.
Services, add-ons, recent PM
  • New tires
  • New CVs
  • New upper control arms
  • New wheel bearings
  • New front brakes, rear to be done but not needed
  • New tires
  • Wool waxed every year.
  • Dobinsons 1.5" lift kit, including upgraded torsion boards (167 rear springs), professionally installed by my local mechanic in Asbury Park
  • Dissent Offroad aluminum front bumper with a small stinger, 10 ¾ “ bullet lights that serve as front turn signals, and a flip up front license plate bracket powder coated black and gunmetal gray
  • 20 inch LED light bar
  • 2 Rigid Industries D series pro flush mount 3 x 3 LEDs
  • Smittybilt (98512) X2O waterproof synthetic rope winch - 12000 lb. load capacity with wireless / wired remote
  • Factor55 Hawse fairlead 1.5 inch thick finished in gunmetal gray
  • Factor 55 Flatlink shackle mount finished in gunmetal gray
  • Factor55 Flatlink rope guard.
  • Metal Tech rock sliders
  • 17” Toyota TRD rock warrior wheels with the beadlocks powder coated gunmetal gray wrapped in Goodyear Wrangler Duratrac 255/75R17 tires.
  • Spidertrax Wheel Spacers - 1.25'
  • Tinted front windows, 15%
  • Fully functional Android Tesla style head unit with wireless carplay. OEM radio included
  • Refoamed all speakers, replaced subwoofer
  • New muffler installed
  • New Heater Ts installed
  • New caliper installed at front passenger. Others were OK
  • New rotors all around 2024
  • New OEM fuel filter 2024
  • New OEM fuel pump 2024
  • New OEM weather stripping around all 4 doors. Very quiet on highway.
  • New swaybars & balance bar
  • Greased & serviced window tracks
Known Flaws
  • Various scratches, scuffs, and paint chips
  • Creases on leather upholstery
  • Wear on driver’s seat bolsters (pictured in the gallery)
  • Some stains on interior carpets
  • Some rust on engine bay, undercarriage, and tailgate (pictured in the gallery) Confirmed to be surface only & totally healthy by trusted mechanics
Recent Service History
March 2019: Coolant flush, Transmission fluid drain and fill with synthetic transmission fluid, transfer case fluid drain and sill with synthetic gear oil, front and rear differential fluid drain and fill, power steering fluid flush and fill, replace coolant fittings
July 2019: Active height control (AHC) fluid flush and fill
November 2019: Front brake rotors and pads replaced, 4 wheel bearings replaced
November 2020: Timing belt replaced, water pump replaced, steering shaft yoke replaced, power steering pump replaced
June 2021: Rear brake rotors and pads replaced
June 2022: AC system serviced and recharged
November 2022: Active height control (AHC) compressor replaced
November-May 2024:
-AHC disabled. Dobinsons 1.5" lift kit & upgraded torsion bars installed
-New rotors installed all around
-New muffler installed
-A/C system serviced & repaired
-New heater Ts installed & coolant system serviced
-New fuel filter & fuel pump installed
-New caliper installed where one had gotten jammed. Others were in good shape
-Steering wheel adjusted & car realigned
-New gaskets installed at downstream exhaust
-Underside fully evaluated for severe rust damage. Frame deemed healthy with surface rust only. Small areas of concern were addressed. Entire underside was fluid filmed
-Replaced anchor points for torsion bars
2025:
-Upper control arms (pass side done, drivers side pending)
-Wheel bearings front
-Brakes & rotors front (rear pending)
Ownership History
The PO purchased this LX 470 in March 2019 and has reportedly added approximately 9000 miles since.
I purchased this LX 470 in November 2024 and has added approximately 15,000 miles since.
EXTRAS
-Several key fobs
-OEM bumper
-OEM roof rack
-OEM radio head unit
I'm deleting my old post and starting fresh. Thanks for reading this far!
My build thread can be found here:
