Nitrogen-filled tires
How about hydrogen. Can you say Hindenberg? I knew you could.
Not only consistent, but for me I've noticed that there is no change in pressure over time. With regular compressor air in 6 months or so I would have to check them and inflate them a few pounds. With nitrogen in them I haven't had a change in over a year. So, that may contribute to a better overall fuel economy.
I can't believe you can make it 6 months! I air up at least every-other month.
12guns said:
Nitrogen shouldn't give you an increase. What it does is keep the air inside from expanding and contracting with the outside temp. Did you add a few PSI when you had the nitrogen put in the 4runner tires? Just a few PSI can help with MPG. Maybe the tires were a bit low before, then the shop filled them back up to spec w/ nitrogen. That would make more sense to me.
PV = nRT. Nitrogen pressure will go up as temperature increases and go down as temperature decreases just like air. I chuckle when I see people with the green caps.
