ARCHIVE Nitro Low Range Transfer Case Gears
Cashmere WA
Website
www.justdifferentials.com
Toyota, Land Cruiser 80,100 & 105
3.12:1 HF2A
Tech Notes:
Includes a low speed gear, idler gear, and silicone.
Toyota Land Cruiser 80 series, 100 Series and 105 Series are among the most durable 4x4 vehicles on the planet. Outfitted with aftermarket accessories and over-sized tires, many have found the need for lower gearing in low range. While not a substitute for Ring & Pinion gearing, these low range gears improve the crawling performance significantly and steep Descent and Ascents become effortless. Easy to install, requires some clearance grinding. Bearing & Seal kit is not necessary, but available if you want to freshen up your high mileage T/Case. Includes Center Differential Low Speed Gear & Idler Low Speed Gear -3.12:1 ratio vs. 2.488:1 Stock ratio.​
http://www.justdifferentials.com/MCTC-1131-p/mctc-1131.htm
Buy Your Set Here:
MCTC-1131
