Next Project/Purchase (3 Viewers)
I would not use anti-seize on these. You don't want them coming off at speed.
Additionally anti-seize throws off the torque specs. They become "wet" torque specs rather than dry, and are different. It's way easier to break stuff as well as you can torque down a lot harder.
(IIRC from my research wet torque specs are somewhere around 50%-60% less than dry.)
Anti-seize is great on stuff you want to remove easily down the road, so there's plenty of things that it's good for (like the cone washers on the axle). Not so good for stuff you want to keep on the truck.
Torque specs are attached. It's for a '97, but it should be the same as yours.
And watch your forehead if you are trying to pull the steering stabilizer :D
I've got the right tool now! :hillbilly:
(You need a pickle fork. Heat + crowbar won't work. Ask me how I know...)
  • torspe.pdf
:hmm: Hmmm you have the right tools.... live very close.... <cough> <cough> When were you planning on helping me install this bad boy :p:D
EDIT: Wow I guess I was a page behind here ...
This is the shizzy right here:
OOOpps I meant:
You can never have too much of either :grinpimp:
But seriously if you need a hand and y'all do this near Grants Pass I'd be happy to lend a hand. And anything you can get an impact wrench too will be made easier by air.
I might be able to lend my garage and a hand, and many a lift has been performed in there!
I would say I have bad memories of doing my lift in your garage, but truth be told I don't remember much at all! :confused:
Sweet... Thanks Guys. I will make time whenever to cruiser over to GP if you guys are willing to help. :)
when I did mine I found that pulling the shocks is the only real show slower, best 45 minutes I've spent on the truck so far. :D
Ask G about the steering stabalizer... :grinpimp:
I didnt buy a SS yet. Will my stock one work until I order. Or is those one of the better wait until I have it to do all at once?
I don't think it will matter much but just don't forget about it. It's an upgrade over the stock one for sure.
Cool. I was hoping to try my lift this weekend, but wont be able to order the SS until next week.
thanks!
So PB Blastering it all week and still can't break nut loose on the shock. From the looks they are (shocks) after-market . Not 17mm nuts like most the articles I have read. They are x2 19mm nuts on top of the shock wrenched down on top of each other.
Picked up a blow torch today :), if that dosen't help then parrifan wax and torch..... if that doesnt work pretty much just going to sawz-all the thing off :D lol.
Any ideas on this but job? Lol. No serial, Ive seen and used 2 nuts to really get a good secure.... not going to vibrate out nut bolt thing before.... but when it comes to un-doing?
Wrench to hold the bottom one, impact wrench on top.
It'll come off.
(I have an impact.)
Woohoo! One side done :) Gabe to the rescue with some grinding of tools, we managed to remove the freaking bolt. Got A shock and spring in :D. Naturally the wife's kept checking in on us.... "ok boys, can we go to dinner yet".
No impact needed either, just a breaker bar. :D
We got a system down too so the other spring/shock on the DS should be easy.
Ty took one. It looks purdy.
We ended up doing it the "dangerous" way. Ratchet strap FTW! :hillbilly:
