So my FJ61 had an unfortunate incident involving a leaky oil pan, the end result being a scarred crank shaft. My dad had a good 2f sitting in the shop so for now we decided to put it in the 61, as that would be faster than replacing the crank in the original motor. We transferred over the carb, exhaust/intake manifold, dizzy, ac, alt, water pump, t-stat, ps, and valve cover. This weekend we finished putting it back together and and attempted to fire it up. It turns over on the starter but won't catch. When the engine is at 7 BTDC and #1 cylinder is closed the dizzy points right at the #1 wire. We verified that we're getting a spark at the end of the wire. Spark plugs were replaced recently, and had no issues on previous motor. We filled the glass on the carb half way with fuel, also tried spraying carb cleaner in the top of the carb while cranking to no effect so I don't think it's a fuel delivery issue. Both me and my dad have double and triple checked all vac lines and wiring, and neither of us can figure out what is wrong. Any help would be much appreciated.
:EDIT: Forgot to mention it has non electronic ignition, in case that's important.
