Hello all,
I am newbie in here, and have been searching for an ideal 100-series for weeks. Land cruisers has been a childhood dream for me, and I hope I'd be able to learn a lot here!
I don't know much about the technical aspects of cars, only the basics (changing oil and filters, etc.), so excuse any bad etiquettes. I am very willing to learn a lot and do stuff myself.
Recently, I think I found myself an ideal(?) truck and did a PPI on it: it's a 2000 Land Cruiser with 190K. 3 previous owners.
It has Timing belt service done recently. It also has ARB front bumper, and speaker and head unit upgrade done.
I haven't seen it in person, as it's a bit far away from me. (10 hr drive)
However, here were some problems found in the PPI:
- Needs valve cover gasket
- Exhaust manifold leak on left side
- ABS codes:
C0205 left front wheel speed sensor signal malfunction
C1223 ABS control system malfunction
C1246 master cylinder pressure sensor malfunction
C1252 hydraulic booster pump motor malfunction
C1256 accumulator low pressure switch malfunction
- Heat shield from both sides are not there
- Front wheel bearing left and right needs to be replaced
- Front rotors out of round
- Horn is not working
- Tires has a few nails here and there
PRICE: 9K - would this be a fair deal? or should I walk away?
I understand that trucks at this age are going to carry its problems, but I also don't want to be spending thousands on it after the purchase, especially considering it's a Land Cruiser.
I guess I am also pretty hesitant because I am new to knowing everything about LCs, just wanted to know what to expect.
Thanks a lot!
- ABS codes:
Thanks a lot!
