well i guess i'm back into some wheeling again now, Diggty rode over to ashville with me so i could look at a 94 fjz80. almost didn't get it the right rear brake was stuck and slightly smoking after a 2 mile test drive. there was no way it was going to make a 220 mile trip back. The PO stated he just had the brakes replaced. i almost walked away but figured it was a good starting point. I called around but wasn't able locate any parts and it was after 6pm anyways so the dealer was closed. I had a few tools in the car so i decided to take a look at the brake. tore it apart and the piston was dirty and had some pitting. brake fluid looked like it have been there from day one 240k miles ago. bleeder was completly plugged. it was clear the calipers hadn't been bleed in a long time. so after some time with some 600 grit sand paper, brake fluid, and some luck i was able to get everything back togeather and working enough to make it home. other then not getting back to raleigh until 315am the trip was uneventful.
The short list for maintenance
had to fix the sunroof front drains.
put a belt on the compressor, yeah, the A/C works now.
used some JBweld to fix the mirror mounting bracket. no more shaking.
took the 3rd row seats out.
hooked up the wiring harness on the kaymar rear bumper. i guess 5 brake lights are enough.
ordered an aussie locker 1 week back order.
ordered some parts to rebuild the brakes, 2 week backorder.
driver window switch need looked at, it work when it wants to.
need to find a winch. i am guessing something north of 9500lbs
i still have to replace some fluids. I hope the oil in the diff's were changed at least once in the last 14 years.
anyway I hope to be ready for some wheeling with you all soon.
