ARCHIVE ( New Product Release ) Rear Motor Mount 's Bolt KITS BOTH Sides OEM Japan Spec. Parts Stainless YAHAHA Cotter Keys Modern Age Metallurgy 1961-7/80
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
Rear Motor Mount 's Through Bolt Kit Both Sides
100% OEM japan Spec. Parts
Stainless Steel YAHAHA Cotter Keys
Modern Age
2024 Metallurgy
#10 Mark Head Flange Bolts / #11 Mark Head Flange Nuts
1961-7/80 FJ40 FJ45
old Toyota Part # "s
90102-13009 / 90102-13010
New Super Superseded Rising Sun Mechanical 90102-13011 / 90102-13012
This looks very promising Matt. I can see where it would be a superior replacement on the passenger side, where the original bolt head often ends up wallowing out the ear of the mount. Conversely, I can’t help but wonder about inserting the driver’s side one up through the confines of the framerail . What is the span across the flange below the bolt head?
do you have a photo of what your referring to mark ?
These were test fit and no interference issues were a factor ,
this is why the Thick stainless steel washers are included
thanks !
not my bolt , but drivers side below :
Your bolt has an integrated flange below the head. What is the size of the bolt head, and the size of the flange below it?
Factory original Bolt Head is a 19mm HEX
Mine is a 17mm HEX ( JIS )
this is why i include the thick washer on each end
Maybe you can send one with my way overdue coolant bottle order.😊
Yes mark , happy holiday day Xmass Tree Eve
I will send you a KIT / pair / set since they’re is a LH & RH set of 2 different part #’s
Perhaps you can evaluate these 2 pipe dream brain children of mine below as well ….🧐
Entering the modern age of metallurgical Rockets Science and Surface Treatment is not such a sour-grape …
