G’day Lex Lover,
You will find most things you need for LX470 here on IH8MUD which contains a vast amount of information in this excellent and helpful forum. Some local Australian insights on “100 series” issues also can be found at
LCOOL and this also is well worth joining, if not done already.
As mentioned by others, a device which connects the vehicle to a laptop and allows scanning of the various onboard Electronic Control Units (ECU’s) is very useful. This involves acquiring a low cost cable and connector (generally of Chinese origin) and software which usually can be sourced by searching for “Techstream” or “Mini VCI cable for Lexus” on eBay or Amazon in Australia or in USA.
An alternative slightly more expensive (but still low cost) source is the following Australian site (based in Perth) which at least provides some contact details – this enables some inquiry and support:
Toyota Techstream Diagnostic Cable – OBD2 Australia
The cable uses the DLC3 connection under the dash, above the brake pedal, rather than the DCL1 connection in the engine bay.
Be aware that the device and software usually prefers an ancient Windows 7 x 32bit laptop. There are workarounds which enable use of more up-to-date computers – a search of “Techstream” on IH8MUD and LCOOL will yield a lot of information.
Also be aware that the software usually requires that the vehicle be OnBoardDiagnostic-2 (OBD2) compliant – which I think yours may be. If so, there should be a label in the engine bay which says so, or a Lexus dealer
should be able to explain. Alternatively, discuss your model, year and VIN with the people at the above Australian link who should be able to help.
Australia adopted the OBD2 protocol later than some parts of the world and some LC100 vehicles (and
maybe some LX470 vehicles) have the earlier MultiplexOnBoardDiagnostic (MOBD) system. My 2006 vehicle has the 1HD-FTE turbodiesel engine and it certainly is MOBD rather than OBD2. The 2UZ-FE V8 gasoline engine on your LX470 may well be different.
It is essential to have some means of checking the AHC and TEMS (AVS) system using Techstream or some other scanning tool.
For AHC purposes, I find it more convenient to use a low cost Mini ELM327 Car Diagnostic Scanner which enables a Bluetooth connection to a laptop, tablet or a smartphone:
Scanner:
Mini ELM327 Car Diagnostic Scanner for Android | Automotive Accessories |
Mini ELM327 Car Diagnostic Scanner for Apple | Automotive Accessories |
App:
ELMScan Toyota - Apps on Google Play
There are other devices -- although there appears to be mixed success with some of them.
Enjoy the LX470 -- it is a great car!
