ARCHIVE New Link Brackets From Barnes 4wd (1 Viewer)
Check out some of the new link brackets we offer at Barnes 4wd!
Looking to increase the life of your suspensions joint? Then the Barnes 4wd Horizontal four Link Truss Bracket is just what you are looking for! By orienting the joint horizontally the joint does not have to flex as much because the joint can move with the axle. We offer this bracket in three different bolt hole sizes and you can run any joint with a 2 5/8” or smaller mounting width. This bracket is cut from ¼” steel. $27.45.
Horizontal Four Link Truss Bracket
Running your joints horizontally can be a great option for upper control arms. These brackets weld to the inside of your frame and we offer them in multiple configurations. These are sold individually. $11.30.
Horizontal Frame Link Bracket
Perfect for a three link or four link suspension system. These brackets are made to be welded to the side of your frame and can be used with any suspension joint that has a 2 5/8” mounting width or smaller. These are sold in individually. $21.98
Upper Inner Frame Link Mount
