New GX Owner here
virginia
Hi All,
I’m a former Jeep (one TJ, one LJ and two JKs) owner. Recently, I bought a 2003 GX470. It’s clean and runs good. It’s the first automatic vehicle I’ve owned as well. So, I have a few questions.
What are some of the common issues?
What batteries, oil, plugs do you use?
Where’s a good place to find parts? Timing belt, water pump, plugs, brakes…etc
I’ve heard that those engines don’t run well on 87 octane. Have any of you seen that with yours?
Thanks
Johnny
2003 GX470 takes regular gasoline per owners manual. Later years might say different. I run regular gas and no issues on my 2003.
I run an interstate battery. Originally from Lexus and then from Costco.
For parts, I always look for oem parts from Toyota, Lexus, Denso, Aisin, etc. Whomever makes the oem part for this rig. There’s lots of online suppliers of Toyota, Lexus, Asian, denso parts. I have a list of online suppliers somewhere on another post….hmmm can’t find it.
Only my suspension components (shocks, ucas, end links), wheels and other upgrades have been upgraded beyond oem.
Common issues:
1. Timing belt and water pump need replacing every 100k mikes or after 10 years
2. Front coilovers sag over time
3. Rear air springs might develop leaks over the years
4. Transmission fluid is lifetime supposedly but should be flushed and refilled every 100k miles. Some are sealed and don’t have a dip stick but the 2003 has a transmission dip stick
Everything else is based on need like the radiator, alternator, cv boots, bushings in LCAs, end links, sway bars.
And of course…if you want to build it up…then there’s lots a of mods to consider
Parts are easy to find for these, due to lots of interchange with Toyota projects.
For "bigger" things (starter, radiator, etc) where I can wait to get them I use Rock Auto. For things I need right away I use the local auto parts store (usually NAPA or O'Reilly's - and NAPA for CV shafts). Dealer-specific parts I usually get from the local Toyota dealer and order them for the same-year 4Runner (for suspension, engine, drivetrain parts, etc). For any engine electronic part (O2 sensor, MAF sensor, spark plugs, etc), get OEM-replacement Denso or Hitachi parts, usually which are the cheapest on RockAuto.
The 2UZ is not a finicky engine so run any good quality 5W30 full synthetic or synthetic blend. Being that the 2UZ holds around 7 quarts I've been running slightly cheaper Valvoline Max Life in mine but will probably switch to Mobil 1 high mileage at the next oil change.
Other common issues not mentioned above are 1) frame rust (make sure you get your GX undercoated with Fluid Film, Woolwax, Krown, or another treatment), 2) failure of the starter (not an easy job as i's under the intake manifold), 3) CV boot joints tend to rip often (but are easily replaced with reman CV axles), 4) the driveshaft likes to clunk if not greased properly, 4) the front brake caliper slide pins like to sieze and rust, and 4) the 8" rear axle has been known to fail if driven excessively hard off-road.
Also, mine is a '07 VVTI engine that "requires" 91 octane. I ran that when gas was cheap but have been running 87 for around 6 months now. It runs fine, save the extra $0.50 per gallon for something else.
The build threads from both Homer and Red who pasted above are full of great info iirc, go to their profiles to find em, and you can see the progression in their builds and ideas from others. Great stuff and good info above from both of them. I love reading internet forums stuff and have been looking into all this for my '03 as well. None of the below is my knowledge - all thanks goes to the many posters and explainers from over the years.
The FAQ and link sections in this subforum and other similar ones are gold. Most of the paths you will want to explore have been pretty well documented. Hit Lexus Owners - Lexus Drivers - https://drivers.lexus.com/lexusdrivers and enter your VIN and get a carfax if you haven't already to check service history.
Radio options to add bluetooth range from radio adaptors $30 to small wire harness devices $75-$200 to full NAV screen console replacements $500-$800. Radio and Nav can be tricky to replace with aftermarket due to system codependency of the climate controls.
The driveshaft lubing is 6 zerks total and you don't need two different greases, early manual had two different specs listed but later condensed down to one spec. Just use some form of NLGI #2 spec grease and you'll be good, moly or no-moly is your choice. Lube the spiders until they express (you will hear the crackle), opinions on the drive shaft lubing vary, most recommend either 1) lube until you barely see it extend, or 2) just add a few pumps of lube in. Excess lube packed inside the shaft can supposedly cause hydraulic-pressure that can cause damage.
Tons of threads on build options and tire sizes and suspension options here and at clublexus and lexusownersforum. General rule of thumb. lifts up to 2" don't require non OEM suspensions components, but above that you will need UCAs at a minimum and possibly more. 265/70 and 255/75 will fit in stock spare location, larger than that (<32") you may need to deflate and ratchet strap to fit or carry via some other method. Rear airbags can be directly replaced with Arnott or deleted and replaced with springs. OEM shock body replacements with on the fly electronic adjustable valving are $$$ so most people go with non-oem replacement if lifting or if shocks are worn out.
Later years with 91 octane recommendation also have secondary air pump (part of VVTI), '03 doesn't have that complication, no problems in the 15k miles I've put on my '03 running '87. They also have extra seals for camshaft when doing TB change that you may see in videos but doesn't apply to '03 even though they are all 2UZ-FE engines. If you're gonna do the TB, general recommendation is to do all the pulleys and tensioner and water pump with it.
Other common issues, gas cap o-ring develps leak with age and throws a code for evap system. Rad cap can be an issue with age. Like all aluminum/plastic combo radiators they develop leaks over time, so keep an eye out for slow leaks via reservoir levels, or pink cotton candy stains/buildup. Consider them to have about an 80k mile life. Get an ODBII bluetooth reader and app for use with it if you don't have one already.
Lots of fake parts on amazon and ebay unless buying from a known retailer. Don't be tempted by cheap lookalikes for mission critical parts. At the same time there is a ton of gx470/prado120 stuff on the chinese sites when it comes to plastic goods and switches that people have good luck with.
Brake booster pump is a less common but common enough issue you may see it. Refurbed brake booster pumps are available. Not many people talk about replacing the brake booster accumulator as well, but I think it may play a part with the booster pump burn out. The booster is the vibration you feel through the brake pedal. Health of the brake booster system is gauged by how frequently it runs, and for how long.
Alternator failure is common as well around the 150k mark, they just need new brushes mostly, so they can usually be serviced, but often people just throw in a new one. Some people upgrade to larger alternator depending on your electrical needs.
Dash cracks can be stopped if caught early by drilling or melting small holes at each end of the crack for stress relief, otherwise they will grow and spider.
Other common basic mods - rear diff breather extension, cargo platform/drawers, rear barn door fold down table, rear barn door strut, headlight polish or replacement, interior light & backing light LED replacement bulbs.
Bumper and wheel well mods can expose airbox to water resulting in hydrolocked engine. Water cross and mod those areas with care.
Seat repair - depends on a lot on your local shops capability, some people use leather off the third row, some buy leather aftermarket that needs to be installed by pro, some go wet okole or other neoprene cover. Using leather conditioner may extend the life.
Many 4th Gen T4R parts will fit, some will need modification.
@fvedmo nice high level summary
as for gas, i have 473k on mine and both the original owner and i ran 87. I didn't notice much difference when i tried a few tanks of 91. rock auto seems to carry a good range of oem and other high quality parts for good prices, but if there's something very specific ill search on here to see other peoples experience.
If you decide to go with a larger wheel and tire setup, be sure to do you homework. I have heard of some people needing to trim excessive amounts (me) and other not needing to trim much at all.
In my case I believe the culprit is my wide wheels and JBA upper control arms.
Welcome!
I run 87 in my 2008 with no problems. I switch to 89, 91, and 93 periodically and notice no difference in power, smoothness, or fuel economy.
