Hi all .
Engine setup : 2F-E with aftermarket ecu using MAP sensor fueling ( Delta 250S cam ). I have a Wideband commander fitted to monitor AFR and help tune the fuel maps
Yesterday I added an extra silencer box in the exhaust pipe . There setup was headers ( 3-2-1) leading to 57mm pipe , large box halfway and out the rear . Now we added another box ( 40 cm ) at the very end of the pipe ( I think OEM is the same ) as I wanted the car less noisy .
When I left the shop I immediately noticed that the AFR ratios were richer . Eg where the gauge showed 14.7 before it now ran at 13,8 .
I actually had to adjust the maps a bit . ( not an issue as I save the maps and can revert if need be)
Now what could have cause this?
1. Change is exhaust setup leading to less scavenging or more backpressure and this affecting fueling ?
2. Welding on the pipe leading to damage to the sensor ?
I contacted Dynojet and they say welding is unlikely to damage the sensor and their sensors cannot be calibrated .
Interestingly the car actually feels like it has more torque ( could be wrong here but this is my perception).
If it is the exhaust setup then it will be great as I will be using less fuel as the maps has to be leaned out to get stoich ?
Is there anybody with so insight as I do want the fueling perfect ( do not want to start burning valves cause AFR was wrong )
